Hi, I have bought a PS3 and have connected i to my 7-40 with HDMI. I also have the PS3 in my STB-list but cant get the IR to work from my TV. In what connection at the TV should I put the IR cable to get it to work ?
Best regards
Hans
Best regards
Hans
You need this:
Perfect, thanks for fast answers ! I didnt realize that I needed a device to convert the signals.
But does anyone know how the 7-40 understands which of the IR-outputs i use for the PS3 ? I cant find any options in the menus. I have set the V. AUX for the PS3 and have selected HDMI port A for it, but I cant choose the IR-control.
Regards
Hans
Hi Hans
You PS3 is connected via HDMI, but it has an AV assigned. If it is in AV2, for example, you have to connect the IR transmiter in the PUC Output of the AV2.
Hope it is well explained.
Of course, I should have figured it out myself. Many thanks for helping me !
Regards
Hans
Hi everybody, got the Nyko yesterday and everything works perfect ! Many thanks. Now I just would like to be able to turn the PS3 on/off with the Beo4/Beo5, does anyone have a solution ? I think I read something about on/off for the PS3 but I can't remember where.
Regards
Hans
I have this and it works perfect
and If you use
Interesting, and if I understand the facts I wont need the Nyko with this gadget ?
