I have a Beovision 7-40 with vertical shadows over the image but not over menues. I have checked and found that the samsung T CON board is sensitive for heat.
The metal shield around the t con bord is marked LV 63-05546A. The number on the board is 40/46/52 HFMC6LV0.3 and the later is easy to find and looks very similiar. But the ones I found refer to LJ94-02306E, LJ94-02328G or something else.
Are they comaptible? Or, what number should be used?
