Dear all,
Even after doing some research I am a little confused about the different versions of BV7-32 that were/are existing. Is there anywhere a kind of table where I can find the different technical specs?
Thanks a lot.
Heribert
Dear all,
Thanks a lot.
Heribert
There are 5 formal mark versions of the Beovision 7-32 as below:-
Hi Keith,
Thanks a lot - this is the first step of what I need.
Can you or anyone also describe the differences of the different types (marks)?
Thanks, Heribert
Heribert,
This is a very big question and so I will only focus on some key points.
Each "Mark" version has a number of assigned four digit "Type" numbers assigned which are sold by country/region and as an example I have listed the Mark V version below:-
Region DVD Reg Type #
North Eur 2 9181
North Eur 3 9182
Hong Kong 3 9183
UK 2 9184
Mark II
The difference between the Mark I and Mark II were mainly the following:-
Mark III
The Mark III made the DVD player an option and the basic spec was as follows:-
Mark IV
The Mark IV is very similar to BeoVision 7-32 MK III with the only major differences related to the screen update, the scaler and the DVD remains optional.
Mark V
BeoVision 7-32 Mark V is based on same design as the rest of the BeoVision 7-32 series, the difference is a general update with 2 HDMI inputs and an optional DVB-HD module and the DVD unit remains optional.
Clearly, all versions benefited from the many software updates and for customers who purchased the early versions (Mark I & II) if they wanted HD they had to purchase a special kit to make the units HD ready.
Hi Keith,
You´re very helpful! Can you answer me one last question?
Do you have an overview in which years the single Versions were brought in the market?
Thanks,
Heribert
Hi All,
Just been looking at the B&O website, there doesn't seem to be a BV 7-32 anymore listed, only sizes are 40 and 55". Does that mean the 32" is no more because Mk V is only a few months old.
Any one got more news on what is going on. Also the Mark V seems to be making more use of the RJ45 port, says for BD-Live and firmware upgates, does that mean they are now planning on pushing software updates over the web?
Steven
