BeoVision 7-32 stand and sound bar with modern tv?
Hi, has anybody managed to convert their BV7 32" stand to mount a newer non B&O TV? And is it possible to use the sound bar with a modern non B&O TV?
I really like the look of the unit, but the TV Panel is getting a little restrictive for connecting in games consuls etc and it's a bit small.
Thanks, Andrew.
STBbrackets.
I had them create a custom VESA mounting plate to mate a LG 55 OLED to a 7-32 stand (motor does not work of course). Looks great.
Hi David, That’s almost exactly the set up I’d like to achieve. Is there any chance you could post a photo of the mount? Did you also keep the B&O sound bar? Take care, Andrew.
Hi David,
Perfect I found the mount. that's exactly what I was hunting. For others here is the link...
https://www.stbbrackets.co.uk/en-GB/product/VESA-non-Bang-and-Olufsen-TV/VESA-Adapter-BeoVision-7-32
Take care, Andrew.
Thanks for the information AndrewEcosse. 🤒
