Beovision 7-32 MK3 and Humax
Auto Power on/off by the BV7 doesn't work for me either, so I use Go+0 manually.
Sad that one can't self-edit the puc files.
Is there an overview of al devies that van be lades intochten PUC of the bv7? I am getting a LG blu-ray player with Netflix on it that i plan to connect to component this week.
I would be interested too.
@Zwets
Not quite what you ask for, but which converter are you plannig to use for that connection?
I tried a hdmi to component convertor and connect to component for the chromecast. I only get sound however. I have now ordered a hdmi splitter which splits of the sound. This way i can connect the chromecast to hdmi and connectbthe splitted off sound to a digital sound in.
I have allready moved the Humax from hdmi to component and its working well and i see. O noticable difference in picture quality.
ill keep you posted.
Hello, Zwets!
How did this turn out for you?
Hi guys,
this is my first post on this forum and I hope I've come to the right thread. I have a Beovision 6-22, and I want to connect a Google Chromecast to it.
First off, I think I need to connect something to the TV to provide an HDMI input, right? I went to my local B&O store and they recommended an HDMI digital to analogue AV converter, something like this: http://www.ebay.com/itm/HDMI-input-Digital-to-RCA-Analog-Audio-Video-Composite-CVBS-Output-Converter-AV-/171837932633
If I understand correctly, I basically need just this device (plugged into the TV and a power source), onto which I can then connect the Chromecast, and voila ... ?
I've found a perhaps related thread on this forum, but that's way more complicated than I can understand:P (and there was talk of Chromecats here on this one): http://archivedforum2.beoworld.org/forums/t/8786.aspx
Any help would be awesome, thank you in advance!:)
Any idea what the command for power off is when I use a Beo4 with navigation button? (1710)
Just the usual red button bottom right surely??
