The STB saga continous....
As you may have red in previous post I am trying to get DTV working on my BV 7-32mk3 with a Humax settop box. I have two Humax models to try. (5000c and 5050c, both are in my STB list)
I have connected the Humax with a DVI to HDMI cable. On the menu I select HDTV for DVI and audio input 4. This is AV4 analog input (or not?) to which i connected the red/white outputs. I get no sound. I am trying to combine digital video with analog audio. This worked on my MK1
As this does not work I connected the SPDIF output (optical) from the Humax through a convertor to digital input 1. All works well..
....But, only when the TV station broadcast Dolby digital. In my case only the first three channels on the DVB-C signal are HD, the rest broadcast SD with stereo signal. On those stations I do not get sound.
On the HD channels i lose sound if i select the stereo channel on the Humax.
Any ideas? Would getting a different brand of settopbox work? I have the Samsung H360r in the stb list.
Help! I would love to have my new TV up and running!
