Is de DVD in the 7-32 serie the same in a Mk1 as in a Mk5 ?
And is it easy to change over?
best wishes, Ken
best wishes, Ken
Nobody out there ?
Ken
Hi Lee,
Thanks for the answer. I have a broken Mk2 and wonder if it's worth taken the DVD player out, before a scrap it.
Ken
Hi Lee, How do I take the player out ?
Ken
Hello Ken,
It is absolutely not worth taking out the DVD player before you scrap it, unless you have another Mk2 you plan to keep for a long time (and why would you, these days?)
If you really must though (!!) then you'll need to remove the back from the TV to access the DVD 'module'. I don't think it's a huge job.
Le
Oke thanks Lee, I had hoped it was de same DVD player for the whole 7-32 serie.
Best wishes, Ken
