beovision 7-32 connect to new apple tv
hi ,
after years of waiting , i can finally buy a new apple tv and need not to worry the HDD capacity anymore . but the new apple tv has cancelled the red/white RCA audio sockets , what will be the best way i connect it to my old BV7-32 with only DVI ? please help .
regards
david
godotz wrote:
hi ,
regards
david
You should be able to get an HDMI to DVI connector ... see Wikipedia's description:
 If you do this you will definitely only get video.  You will need to use the audio via optical.  Does your BV7-32 have an optical connection with the same input for the DVI?  If so it should work.  I say that's why they included the optical because some older HDMI to HDMI had compatibility issues and unfort didn't stream audio (although i never faced this).
BeoVision7 does not have optical input only coaxial. You will need an optical to coaxial convertor to get audio into the television.
Opman
thank you for all your advise . i did the HD upgrade and have the coaxial input . anybody tried that kind of optical to coaxial convertor ?
I am using a converter with my set top box (dreambox) and beosystem 2 (with attached panasonic display).
Around 15 Euro on ebay.
A cheap one is enough, it is only digital conversion.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
thank you ralf .
