Normann wrote:
DoubleU wrote:
Normann wrote:
I have connected it to av2 with an scart converter and i am using a line level signal to port a1..
Your TV expects a digital signal and disables the sound from your AV2 port.
In your connection menu, disable your A1 port and set it to NONE.
I have noe diable the A1port, but still no sound.. I think this is strange.. 😮
I think the interface is expecting to see a video signal to indicate that the source is alive before it activates the audio processing 🙁
I don't have a BV7 myself, nor a BV7-32 manual (I am using a -40 one to advise you)
But can you try AV5 or AV6 ?
AV5 might work as [PC]
AV6 will respond to the [CAMERA] command - and might work.
It could be that the BV7 is too "smart" (or tricky!) to be fooled into just processing an audio signal 🙁
