BeoVision 7-32 and Beosound 7.1? Can a Beolab2 be added?
Hello B&O experts,
Is it possible to add a Beolab2 to my BeoVision 7-32 MKIII and Beosound 7.1?  I have tried to configure it but the Beolab2 is always greyed out on the menu when the Beosound 7.1 is selected as centre speaker. I cannot figure out the correct way to connect them all together, hence my request for a solution to the experts on here..
Thanks in advance,
David
Double post.
Guitardaddy wrote:
Hello B&O experts,
Thanks in advance,
David
Hi David,
Try defining your BeoLab 7.1 as LEFT and RIGHT instead of CENTRE. You may need to plug its Powerlink cable into a different socket on the back of your BV7-32.
Once you have a LEFT/RIGHT it should let you specify a subwoofer. At least this is how it worked on my BV6-26.
Good luck,
Lawrence
Isn't it possible to just to keep current configuration.
BL7.1 as centre speaker.
Connect PL cable from Center PL output of the TV to the BL2 input PL socket.
Connect another PL cable from BL2 output socket to the BL7.1.
R.
Thanks for your response.....much appreciated! I will give your suggestion  a try.
Thanks again,
David
Thanks for your reply.....it's much appreciated! I will certainly give your suggestion  a try.
Thanks again,
David
