BeoVision 7 - 40" MK IV
ed7 wrote:
Is still a samsung panel??!πŸ‘
So? The Avant was a Philips-made tube!
I know i owned both types avant& bv,i was asking if b&o still using samsung panels?i thought they stopped future co-operating with samsung!!! πŸ™‚
Roger wrote:
Based on the spec's I've seen they haven't included TrueHD or DTS-HD among the BS3 sound formats, so I do hope that the new internal bluray will do the decoding and pass it on as PCM to the BS3 - anything else would be embarrassing for B&O.
Oh god, good point. As I'm assuming the existing drive is merely a drive with a scart-type cable to the main motherboard, I seriously doubt they are going to get a chip capable of decoding the audio then passing it to the BS3, in the new Blu-ray internal drive. Surely the drive would merely be a drive mechanism update?
Why? Well, it's a drive mechanism replacement for the existing BV7-40 MKIII (and only Β£400, which is 'cheap' for B&O), so there's no way you are going get True HD decoding built-in to a Β£400 internal player.
B&O are gonne kill them self if they dont start making up to date produkt 😑
Im not gonna spent about 12-13.000 euro on a outdatet produkt, and i dont think im the only one πŸ˜‚
You are not alone. I just bought a Loewe 😁
B R
Clakke
From what I heard they're switching to Sharp panels. I have this from what I would say is a somewhat good source.
Meaning not always right, but more often so than wrong :-)
That is definitely a step in the right direction ,was not impressed at all with samsung panel picture quality!!!😐
B R
Clakke
You are definitly not alone. I just bought a BV7-40!
Simon.
24p = Yes Mk III and MK IV got 24p support.
And moxxey itΒ΄s not a scart cable between the dvd drive and the motherboard. They use computer IDE Ultra ATA cabling..
And they are going to use Sharp panels in the new BV8-40 and the new Bv7-55, but the Bv7-40 MkIV they still use Samsung, but the new 2-4ms 120Hz Ultra Glare panel.
Samsung are far ahead Sharp in LCD technology, so i donΒ΄t think you should be disappointed because of that..
Regards
BV7 mk III does not have 24p.
Do you know when the new 55" BV7 are arriving?
