BeoVision 7 - 40" MK IV
When the new BV7 - 40" mk IV arraive in april with blu ray, does any one know if it can play all new HD sound formats incl DTS Master. Will it be a profile 2,0 so its can be opdatet over internet.
I know that it will be Full HD, 100Hz panel, but will it be 24p?
What can you all tell me about the new BV7..........
Based on recent history, I don't think you want an open door for Bang & Olufsen software to find a way onto your TV!
very good question anyone??
So secretπŸ˜‰
πŸ™‚
No one dare comment for fear of sparking the BS3/BV7/HD audio argument again!πŸ˜‚
πŸ˜‚πŸ˜‚
B&O have decided that future (high-end only?) BeoVision's shall be able to connect to the internet to receive S/W updates.
DTS-HD: BS3 works fine today as long as you have a bluray player that will decode the DTS-HD signal and pass it on as multi-channel PCM. Based on the spec's I've seen they haven't included TrueHD or DTS-HD among the BS3 sound formats, so I do hope that the new internal bluray will do the decoding and pass it on as PCM to the BS3 - anything else would be embarrassing for B&O.
Roger
wireless sw updates ? now that IS impressive
this tv looks like it might be the new avant !
Is still a samsung panel??!πŸ‘
Flappo... no one mentioned wireless...
