BeoVision 6 is back on www.bang-olufsen.com the updated one
While browsing the bang and olufsen website I stumbled on the BeoVision 6, it seems to be the
updated BeoCenter 6. A beautiful TV and far too late updated in my opinion!
The specs:
2 x HDMI inputs
1366 x 768 pixels panel (HD ready)
Optional: Dolby surround module and DVB-HD
Link:
http://www.bang-olufsen.com/beovision6
The specs link:
link
Regards, Robert
Great, the design still holds 100 % and the BeoCenter 6 always was a bit silly.
Best regards
Christian
Best regards
Christian
Agree, never understood the radio bit. As a result i have the BC6 with the radio module removed and DTV one added (which gives you digital radio stations ... )
Christian
It is a BC6 with the radio removed! Optional extras include a Digital Surround Sound module (which is a factory fit option) and the afore mentioned DVB-HD module (this can be fitted later but is cheaper to get supplied with the set). It shares the same chassis as the BV7-32 and BV8-40.
Does the chassis you mention have any of the beosystem 3 components - as with the new BV7-40?
I'm thinking of upgrading my BC6-26 to a BV7-32 and hence the question
The 7-32, 8-40 and 6-26 share a more basic chassis than the 7-40.
Will the new up-coming beovision 10 have the same chassis than the 7-40
What price can we expect
I notice that the speaker grill remains unchanged and still looks like the Centre.
Beovision 10 will share the same chassis as BV6, BV7 32 & BV 8 40.  Price should be around £5500 - £6000.
how much is that in euro's🤔
