Beovision 6 22 and apple tv ?
Hi I have recently got a beovision 6 22 and I am looking to connect to a apple tv box ,however it only has scart sockets! How am I best to do this ? also it says hd tv but no hdmi input ? please can someone tell me if I get a hdmi to scart converter box and rig up to apple tv will this work ??It is one of the earlier beovision 6 with cloth speaker cover
It has DVI socket!
mr_5F00_anders_5F00_son wrote:
It has DVI socket!
Try a DVI to HDMI connection cable. I have used one once
You will probably not get audio, only picture, that way.
So you need to use the Audio L/R in of the TV (that are used in a DVI PC scenario).
Depending on your apple tv version you might need a converter...a DAC (can easily costs as much as the apple tv / even more).
There are converters HDMI to scart as well (hd fury, if I remember correctly).
All in all no fun to set this up.
Easier to get another TV ;-))
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
For audio you can use this converter, it is cheap and works perfect:
http://www.amazon.de/Digital-Toslink-Analog-stereo-Konverter/dp/B004O2P0CS/ref=sr_1_1?ie=UTF8&qid=1379497281&sr=8-1&keywords=digital+toslink+spdif+zu+analog+stereo+2xrca+audio+konverter
Greetings
Räuber
Great!
I did not know it was availabe at this low price.
So, shopping list:
HDMI - DVI cable
Digitial / Toslink SPDIF cable
Converter as above
RCA cables
Please let us know about the results!
Ralf
Many Thanks for that will start getting sorted !Cheers guys
Which model ATV do you have? If you have ATV2 (Black) follow the suggestions so far.
If you have the ATV1 (Silver) there is a much easier way to connect to your TV using ATV-Flash from firecore.
See here for an old posting if you have the ATV1 andlinkto how easy it is to use the ATV-Flash software. ( You can make the wor-around happen yourself if you link! But too technical for me)
You would then just need one of these and the cables and you'll get sound and pictures over scart. I use this with my BeoVision 5 (SD) and Silver ATV. And it works really well.
Stoobie
Exeter,
Devon,
UK
Hi it is the atv 2 black one only bout 6 months old , so can you just explain exactly what I need again and can I get this socket in uk, its all getting quite complicated !!
