Beovision 5's now worthless?
This Beovision 5 has just ended on eBay with no bids and an opening price of £199.
http://www.ebay.co.uk/itm/Bang-Olufsen-BeoVision-5-42-480p-EDTV-Ready-Plasma-Television-/331546747025?pt=LH_DefaultDomain_3&hash=item4d31b9e091&autorefresh=true
The £13000 TV took about 10 years to depreciate to 10% of its initial price, and then another 90% of this remaining price went in about a further 4 years. 14 years total to drop to 1 or 2% of the original.
If the LCD screen and its later derivatives had not come onto the scene so quickly the BV5's might still have been fetching £5k. These were/are such great televisions, but the cheap well designed flat LCD screen has all but wiped them out along with all the CRT models. And who wants the trouble of moving and transporting such a heavy machine? The BV9 even worse.
My own BV5 still gives service in our back room. If and when it finally fails I will be more likely to put in a new £200 42" screen and hide a new receiver and speakers in the lower half rather than either attempt an official B&O module repair (or taking the TV to the tip!
And what can dealers do? With prices dropping like a stone there is too much risk in taking on these models. Unless you can resell within a few weeks you will have no profit!
Graham
Just like the original Avant unfortunately. The picture quality of the new range of TVs is amazing, and even give my might 7-55 more than a run for its money.
Ultimately though the connections of the 5 & 6, simply make them unfashionable to most.
...and the BV7-40 MK1 and 2....
It's all about HDMI I'm afraid.. Anything big, and SCART only is dead now unless it's so cheap it's a no brainer.
I used to pitch the BV5 as a great kids room TV when the price crashed, but kids all have PS3, PS4, Xbox etc with dazzling graphics the poor old SD BV5 just can't show.
Lee
Lee
Good point!
How did SCART ever become a standard in Europe? The terminal connections are so vulnerable to the slightest movement causing one or two pins to have poor connections so that the sound or colour is defective. Every time our kitchen 6-23 gets moved on its wall hinge you can bet that something happens with the SCART.
Graham
They did because they offer way more posibilities than other analog A/V connections.
The problem (you describe) could have been solved, if all scart connections had some sort of fixation mechanism - like we know it from the old Avant.
But this is now - fortunately - history. It has always been a pain to make the cables fit right in anyway.
HDMI makes life easier - although they could also sometimes benefit from some fixation.
First of all - it would be nice to have plugs, that fit in no matter how they are turned around.
It's the story of every technology. If you spend £13k, and someone else paid £2k in the used market if the £2k had HDMI it probably would be considered better by a lot of people
HDMI is always better than SCART
I paid $10k for a Pioneer Plasma that I had to give away many years later. It was one of the first TV that had HDMI and the came in 1080p and mine was 1080i, so then I moved to ten Sony which was better visually even though I wanted plasma I settled on LCD. The only plasma was Panasonic and back then they made the fugliest TVs so .... No thanks.
Tech has moved so fast. It's really all planned obsolescence
The BV5 is a very fine looking set, but for a lot of people it's like a CRT size in a different package when you can get a lighter panel only TV.
The Sony I have in my bedroom is on a picture frame and I don't even have it screwed into the stud it's so light. It's madness but, people who don't know a lot about TV is all a bout connection, lightness, thinness and sound and pq second. Which makes the former unfortunately in the same league to a lot of people 😡
My BV9 is the centerpiece of my LR. For pic quality, it is still more than satisfactory. I have many peripherals leveraged to it. I don't see a replacement for me on the near horizon, unless the panel dies.
It is ー at once ー contemporary, impressive, integrated and its overall gestalt is so throughly BnO.
What more could you ask? What more do you need?
I'd sooner save my sheckles for the BL5 successor...if it proves it's worth to me.
B
x2.
This is exactly how I feel at the moment, right down to your last comment about BL5 successors. My next purchase will be BL5s otherwise. I also intend only to change my BV9 if it dies; hoping there may be something aesthetically different looking than the current Avant at that time.
B
We are not talking 'plasma vs lcd' here.
The point was, that 'pre-HDMI tv's' aren't worth a dime nowadays.
The BV9 is a fine set, that can serve you well for years to come....if you have the space for it in your room/house.
