Beovision 5 Upgrade
Hi everyone, I have one of the last HD (720p) versions of the Beovision 5. I'm quite happy with the picture, having converted the latest Apple TV box to work via DVI and a Digital to Anologue converter. However, I'm aware that some members of the Forum have replaced the original screen with a 4k panel. I love the design still, and the sound still impresses, so if I wanted to upgrade the panel, how is it done and what panel would be suitable -- plasma or LCD / LED? Many thanks.
If you're happy with the picture I wouldn't bother!
What A to D converter are you using? - I presume just an hdmi audio extractor, rather than reducing the digital video signal to analogue?
Hi, thanks for that.
My Beovision 5 has a DVI, so the set up for a new Apple TV, which only has HDMI and digital optical output is:
- HDMI to DVI cable from Apple TV to Beovision 5 (but DVI doesn't Carry sound)
- Digital Optical out from Apple TV to Digital to Analogue converter box
- RCA out from box to Scart Beovision 5 input
- Select 720p resolution on Apple TV.
Works a dream. And I have multiple HDMI devices running through same DVI connection using a Scart switch. Ask if you have any questions. Still an iconic TV. Thanks.
That all makes sense - although I am not sure what you mean by a 'SCART switch' when talking about hdmi and DVI.
I was also a bit confused because the latest Apple TV (ATV4 or 4K) does not have an optical output, so would not work in your current setup.
There's one on ebay already converted with a 4K panel....some pics.
Doesn't look like it takes a lot off work looking at the rear
Hi, yes you're right. I have an earlier non 4k version (forgot as have both). This one has optical out. The Scart switch is just a multi scart block. Needed because have Humax also connected via same setup. So to switch to humax i need to deselect apple tv sound and select humax (both go into same multiscart). Cheers
That's very cool. Will check out. Thanks
I changed the panel in my BV5 and did a step-by-step guide.
You find it here:
https://archivedforum2.beoworld.org/forums/t/41909.aspx
I can’t find you step by step guide on that link :) can you point me in right direction?:)
I just double checked the link.
It works for me.
It will bring you to a post with topic:
Beovision 5-42 upgrade/replace screen
As of page 2 you see the process with high resolution photos step-by-step
