Hi
I have a BV5 which will not accept timer programming. Instead of storing the source day and time etc it freezes on the last step and exit must be pressed to return back.
Any ideas anyone?
Regards,
Hi
Any ideas anyone?
Regards,
I think it would be easier to get an idea, if you`d tell us more about your setup....
-Is your BV5 part of a ML system?
-T V.OPT ? Master - Slave?
- Which video devices are connected?
Stefan
Hi Stefan,
The tv will not accept a timer programme even when its complete disconnected from the ML network i have checked to make sure its set as a master. Its gets as far as asking which days you would like to set, inthis case simple delete saturday and sunday from the list leaving MTWTF.. when you press GO to set the ok on the screen goes red but the screen freezes - you have to press exit to get out.
Hope this sheds a bit of light...
Regards,
Darren
Please forgive the obvious question, have you powered off for a few minutes then checked that the time and date are set correctly?
Opman
