beovision 5 or 7 ??
Hi All
I have a beosystem av900 with a pair of 8000's and 6000's
I am looking to replace the TV ideally with either a Beovision 5 or 7 (42") I have noticed that the used prices are almost the same for both so any direction on which is the best ? - I know little about the LCD V Plasma debate
Lastly am I correct in thinking my speakers and ouverture will work with either of the new TV's?
kind regards
At a guess, the 7 will be a relatively early one so I would get the 5. If you can get an HD ready one, it has a great picture and is almost as stylish as your AV9000. Your system will work perfectly with either set.
