Beovision 4 65" HD?
At that serial it will not be an ACM (curved bezel) version.
I'm going to stick my neck out and say that with that serial number it'll be a 1080p flat bezel. If it is, the type number should be 9033.
Lee
The serial number quoted above is a BeoVision4 65 type 8993. This means it is a Mark1.
Opman
A man with access to ROS - you're one up on me.. LOL - Thank you Opman.
With a BeoSystem 3 feeding the screen it won't be too bad a PQ though. If it's cheap, go for it.
Lee
Very good value compared with the original price, obviously that's because it's a huge, bulky, power-hungry and increasingly antiquated set which probably has limited appeal to most buyers.
Still for the money it should make a pretty impressive home cinema system if you've got the space! The 7:2 sounds great.
