Hi!
I just bougt a pre-owned BeoVision 4-50 MKIII Serial no. 1936XX85 with a BeoSystem 2 MKIII 1896XX92. So from what I can understand they both should be HD-ready. The BV-50 has an DVI-input on "SLOT 1" on the back. I have connected my computer to the DVI-input and from what I can read in the manual that could be done. It says "HD equipment can be registered with the AV, Decoder and Camera sockets. Camerea is accessed by highlighing Decoder and pressing the MENU button on Beo4". The only problem is that I can not get acess to the Camera settings by doing as the manual says. And therefor I can not get the picture from my computer to the BV-50.
That made me think that something is wrong? Maybe the panel is not updated or something? I went into the service menu and found this:
Monitor informaiton:
EEPROM ver. 050
Plasma version setup:
PDP 50 D7 Blank delay 0200
VGA-input PDP Slot1 PDP Slot2
VGA/YPbPr None None
CVBS on CVBS on CVBS on
Camera ---------- ----------
That made me wonder if the DVI-input really is configurated in the menu. Can somebody else see what they have for settings in this menu?
I can of course try to get the picture from the computer via the Beosystem 2's VGA-Input but that's not what I want.
If somebody knows anything about this or have a similar TV and can check there settings in the service menu I would really appreciate it.
Thanks!
