Beovision 4-50 mkIII, beosystem 1, plus HDfury FOR HD picture?
Has anyone tried to use HDfury to connect HDMI to the BEOSYSTEM 1?
Perhaps the opposite of that...
I use an HDFury to send the video from my BeoSystem 3 to the VGA input of a Sim2 projector. It works flawlessly. It covers the HDCP issue as well.
I suspect that an HDFury will become necessary to connect the new Apple TV (with only HDMI out) to a BeoSystem 1.
My word of caution: Be sure to pay the extra amount to get the power supply cable to connect the HDFury to your mains. Otherwise, you'll get quite frustrated and it might not function.
any one can help me i have beosystem 2 in 3 years i dint use it but i forgot the pin code can any one tell me how can reset it ty
contact your dealer
first time poster... hard to get any other help than this, sorry.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I know what you're thinking Ralf, but I don't think we are supposed to adjust the amount of help according to how many posts a person has.
Plus, it's totally irrelevant in this case - there's nothing you could do about a forgotten PIN yourself even if you had posted two thousand times.
So, contact your dealer. 😛
What happens if I plug bluray directly into beovision 4-50 and unplug beosystem 1. Keeping the ir eye plugged in. Can I bypass beosystem one this way. How do I use beo4 remote for this.
