Alex,
Thank you, Not sure my receipt shows a serial number as 18251481 so that puts me in the pre-D7 range according to your post. The menu lets you look at the monitor info and the serial numebr it lists relates to the BS 1. Under TV there were several listings one indicating a "D6 2B" I think (it won't show that info now for some reason). Is it reasonable to assume this may be a D6 panel and will not work with a BS 3 at all similar to ahoover?
Roger
