Alex,
My Bv-4 is wall mounted and I can't see any serial numbers, etc.I know there is a way to check the panel type by using the Beo 4 thru menu functions, but I can't recall the button sequence, can you or anyone else here help with this? I purchased my BV-4 in Aug 2006 prior to the BS 3 release. I think I should be able to utilize the BS 3, but I want to be sure.
The reason I am suspect, is because after the system was installed, I was double checking my serial numbers, etc.numbers to what was on the receipt and I noticed some errors that my dealer could not explain making me think I purchased used or referbished equipment. I don't think this is the case but it sure would not surprise me if B&O sold me an older panel with new skin!
Roger
