Beovision 4-50 Compatibility with Beosystem 3
Hi:
I have a Beovision 4-50 Type 8952, Item 1895226 with a S/N ending in 5309. I am currently controlling this with a Beosystem 1 and I'm thinking of upgrading to a Beosystem 3 but need to know if it is compatible with my Beovision 4-50 and are there upgrade/support issues.
Thanks in advance!
Al
Hi Al,
Best check with your dealer or B&O technical directly - they can tell you straight off the serial number.
I don't recall any issues with BSYS-3 not being compatible on older BV4's - but you best check with the dealer.  If it's not a HD ready panel though, getting a BSYS3 won't help you achieve HD.
Thanks,
Martin.
Actually there is an issue, the panel must be a D7 or newer.  If not it will not have the DVI socket to connect the Beosystem 3 to it.
You can add the DVI card and flash the panel with new software...
If you don't have the DVI input I think your panel is a SD panel, BS3 can only be used with HD or FHD Panels.
some of the 50" panels that dont have the DVI cards built in but are HD at 1366x768 and still can use BS3. All you need is the DVI card added and flash new software on the plasma. I'll find out the exact serial number for you.
I just checked my Beovision 4-50. Looking at the rear from left to right:
Slot 1 Empty
Slot 2 & 3 below:
AUDIO IN - Right - RCA Phono
AUDIO IN - Left - RCA Phono
S-VIDEO IN
VIDEO IN - BNC
VIDEO OUT - BNC
AUDIO - Right
AUDIO - Left
Component VD - BNC
Component HD - BNC
Component PR/CR/R - BNC
Component PB/CB/B - BNC
Component Y/G - BNC
PC IN - DB-15 Female with Audio Mini-jack
SERIAL - DB-9 Female
Looks like I will need to add a DVI card fofr HD if I want to use a Beosystem 3.
Thoughts/ideas anyone?
Thanks in advance!
Al
That sounds like a very early BV4-50 which it may not be compatible with BS3 even with the DVI card
Alex,
My Bv-4 is wall mounted and I can't see any serial numbers, etc.I know there is a way to check the panel type by using the Beo 4 thru menu functions, but I can't recall the button sequence, can you or anyone else here help with this?  I purchased my BV-4 in Aug 2006 prior to the BS 3 release.  I think I should be able to utilize the BS 3, but I want to be sure.
The reason I am suspect, is because after the system was installed, I was double checking my serial numbers, etc.numbers to what was on the receipt and I noticed some errors that my dealer could not explain making me think I purchased used or referbished equipment.  I don't think this is the case but it sure would not surprise me if B&O sold me an older panel with new skin!
 Roger
Okay... here we go....
BeoVision 4-50 D7 after serial number 18363212
BeoVision 4-50 D8 after serial number 19207508
as far as to check on your beosystem 1 i dont recall where it is exactly in the service menu but if you browse im sure you will find it. Just push MENU MENY 0 0 GO to access the service menu.
