Beovision 4
Hi all,
I've been offered a second hand Beovision 4 42" non HD and Beosystem 2 for not a lot of money. I've not seen it as yet, but believe it's in very good condition and lightly used.
Whats people's opinions on this TV? - picture quality, reliability etc. Any known problems?
Many thanks
Mark
Very good quality and reliability. Depending on the age of the panel it MAY be able to upgrade to HD, via a software update in the Beosystem 2 and a firmware upgrade and blade in the Beovision 4. I'd check with a dealer to see if the serial number denotes it as a D6 or D7 panel - if it is D& then you are laughing.
Either way, if you are only looking at SD material, then it is a fine unit.
is every d6 panel upgradeable?
