hi i was wondering if i can make a replica.
i have a
TH-65PF10WK
its a 65" panasonic Plasma (i was told that B&O used the same panal)
i got it cheap on ebay and i also have a beosystem 2.
i asked B&O in Sydney australia to get me a price on a gold frame for the 65" and they told me that it will cost me $950
i have connected the beosystem 2 onto the plasma and it works fine like it was made for it. the only thing is that when ever i need to use the HDMI i have to change my input with the panasonic remote.
the beosystem 2 is not made for HD. i wish i had the money for a beosystem 3 but i don't.
now i was hoping that i could fix the frame onto the panasonic plasma so it lookslike a beovision 4 65 and use the beosystem 2 so i can use it like it was a B&O setup.
dose any one out there own the new beovision 4?
i was hoping that you could take a few photos of the side and the frame.
also if anyone out the has a beovision 4 65" pls get in contact with me as i really need the measurement of the frame.
thanks
hilton
my problem is that i dont know 100% if the frame will fit has any one out there tryed this?
i use to own a older beovision 4 50" and you can see that the fame would fit most 50" panel
