am i right in thinking that you lay the BV3 on its back to fit a motor base, or am i about to make a horrible mistake?!
Ray
Ray
If you lay it gently for a few minutes on any side you will do no damage. Use plenty of cushions or a duvet and all will be fine. Lots of people will give advice about transporting CRT TVs but for a short period you need not worry.
Many thanks guys, i'll try it on its side. Its only to fit the motorised base so only five or ten minutes 🙂
Ray
