Beovision 3 motor stand
am i right in thinking that you lay the BV3 on its back to fit a motor base, or am i about to make a horrible mistake?!
Ray
If you lay it gently for a few minutes on any side you will do no damage.  Use plenty of cushions or a duvet and all will be fine.  Lots of people will give advice about transporting CRT TVs but for a short period you need not worry.
If laying it on one side is possible, i would prefer this. Transported mine this way in a car, for example,
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Many thanks guys, i'll try it on its side. Its only to fit the motorised base so only five or ten minutes 🙂
Ray
