Beovision-3 and N-Music
According to this FAQ http://www.beoworld.org/faq_view.asp?id=20 it's possible to activate N-MUSIC on my Beovision 3-32. But how can i do this??? The Beovision runs in option 2 (and an old Audio-master connected via ML-MCL converter with option 0).
Any idea?
All beovisions are compatible, it is the Audiomaster that can be compatible or not.
Your audio master is not.
What is your source of N.MUSIC? Beoport? Beomedia1?
The source will be a Beoport.
I agree, the default is to have a N-Music compatible Audiomaster.  But in the link above its written different: "If you set the BeoPlayer PC2 to option 2 (Audio Master) you do not need a compatible BeoSound music system, but you will need a BeoVision with N.MUSIC."
And this is what I'm trying to achieve.
