BeoVision 3 32" Usage
If it is anything like my 28 inch RF Avant, you can check in the service menu by pressing MENU, going into the setup menu, then hitting 0 0 and ok. If the BV3 is different, I'm sure someone will be along to correct me!
Just tried it on my BV3 32" & the menu instructions from john accesses amongst other data monitor info' including "video (days)". I am assuming you just divide the figure by 24 to get the number of hours, but I'm sure someone will correct me if that's wrong!
