Hello,
I considering a Beovision 11 - 40 for my livingroom/dining room. Part of the functional requirements is that the TV should be able to be turned 90 degrees out from the wall while on wall mount. In images and videos I have seen demos of it doing so.
However, I talked to a re-seller of used B&O and he said that while the wall mount can turn the TV 90 degrees it is not practical to do it on a daily basis, something about the mount not being strong enough to keep the TV at 90 degrees out from the wall even if the wall mount is motorised.
Can someone confirm that this is the case?
Best regards,
