BeoVision 11 problem
Wait for at least 3 hours with the TV connected to the mains. The TV should then allow you to put in the PIN. Every time you disconnect from the mains the 3 hours will start again.
If that procedure does not solve the problem you will need to contact a dealer. Similarly, if you do not have the PIN.
Putting in the wrong PIN 3 times will also trigger a 3 hour wait. If your TV wasn't ever set up with a PIN you may have a different problem.
Graham
Hello,
I am waiting now for 3,5 hours (wel the red light is flashing), but the BeoVision wo't turn on. Do you know other solutions for my problem?
Thanks for the help!
Piet
What I would do with mine in such a case: Open the Beotool App on my iPhone, check the BV11 status on it and generate a service report.
HI,
Thanks for your response.
I have the Beotool app open, but he can't find the BV11. I think because the BV11 can't start up and hasn't a internet connection right now.
Piet Hansen wrote:
Hello,
Piet
The 3 hours may not be a precise time. I would leave the TV connected to the mains overnight before trying anything else.
Graham
Hello,
The BV11 stood the all night on with the red flashing light, but he does not asks the PIN and won't turn on. I don't know what to do right now. Do I need to wait longer?
Piet
I would contact a dealer. It's possible that you've made a disconnection from the mains whilst the TV was doing a software update.
Perhaps someone else can advise on resetting the TV defaults in this situation.
Graham
From the maintenance manual..... table is scrambled but if you upgrade you can see the original on the main site.
“Flashing red, 13 blinks per 10 seconds... theft protection after too many failed PIN attempts. Switch on not possible.” Is that the problem? Contact your dealer. Do please let us know the final outcome so that others can learn!
Graham
Indication
Green
Red
No errors - no timers programmed
Off
Off
Overheating (red/green LEDs are alternating)
 approx. 6 blinkings per 10 sec.
TV is cooling down in Standby (after overheating)
ON
Theft protection ON, product has been disconnected from mains for too long. Pin code required to switch ON the product
Theft protection ON, PIN-code entry locked (not possible) due to too many failed PIN attempts
 approx. 13 blinkings per 10 sec.
SW downloaded from portal. Product should not be disconnected from mains
On
SW being burned into FLASH. Product should not be disconnected from mains
Blinking 2 times followed by ...
 ... approx. 6 blinkings per 10 sec. until completed
Product is ON but no picture
On
Option programming the product
300 ms
Press Standby on remote control to verify that the product is connected to mains
Indication
Green
Red
Off
Off
ON
On
On
300 ms
Hello,
After a long time waiting is at an Bang and Olufsen dealer the entire motherboard of the BeoVision 11 recplaced. Thanks for all the help!
Piet
Piet Hansen wrote:
Hello,
Piet
Good that you got help.
Did they charge you for that? If so, how much?
