BeoVision 11 Problem Detected
Woke up this morning and my BeoVision 11 was already powered up with a message on screen stating a problem has been detected with three options, 1. Restart, 2. Software Update and another which I don’t recall, so selected option one and just shut down, tried to turn on and you’ll hear the attached speakers click on and the scrolling Bang & Olufsen, then the screen will go blank and turn off again, it’s on the stand which will not move during this time.
was hoping someone else has had this issue and it was just a simple fix because I doubt I’ll be able to get an engineer in.
Thank you all
Sitting: BeoVision 11-46 on Motorised Floor Stand - BeoLab 11 Wall Mounted - BeoRemote One - BeoCom 5 with Speaker Base Dining: BeoGram 3000 Type 5228 - BeoSound Core - BeoLab 28 - BeoRemote Halo Kitchen: BeoSound 1 - BeoRemote Halo - BeoCom 6000 Bedroom: BeoSound 35 - BeoRemote One - BeoTime Guest Bed: BeoLit 20 Study: BeoSound Core - BeoLab 8000 - BeoCom 5 on Speaker Base Gym: BeoPlay A9 On The Go: BeoPlay H7 - BeoPlay H5 - BeoPlay E8 3.0 - BeoPlay H95 - BeoPlay EX
Did you try to unplug the mains for a few minutes?
Thank you for replying Fansastic, yes I left it a hour unplugged for a hour turn it on again and the options appeared again but this time I clicked on the factory reset at the bottom of the menu, resolved it just had to redo all my settings, add cabled speakers and multiroom linked speakers like the BS1 and BS35
