Beovision 11 movement Blur / pixalation
Hey there
i just bought a new Beovision 11 - 46' tv
when i watch movies the picture somehow starts to pixelate during fast movement / fight scenes - its only where The fast movement is. It looks terrible and is very distubing. I had No problems Like This With my old plasma tv on The same Apple tv and internet conncection
anyone knows a soloution?
The solution is to turn the motion compensation OFF – (FILM MODE, MOVIE MODE, JUDDER CANCEL, etc) – I don't remember what this setting was called in BV11's settings, but I'll check when I get home.
Turning the artificial motion compensation off should solve the problem.
It's JUDDER CANCEL in the picture settings. Turn it off. That should solve the motion issues.
(I realized I had all my BV11 settings as photos in DropBox – you know, just in case I ever make a full reset – so I didn't need to get home to check this 😁)
I have done What you Said - and it seems to be working
many many thanks
many many thanks
🙂 you're welcome!
Now just "Lean back and enjoy" – as they said in a title in a B&O catalogue many, many years ago.
KMA wrote:
you're welcome!
Now just "Lean back and enjoy" – as they said in a title in a B&O catalogue many, many years ago. KMA
Current setup : BeoVision 11-46 with Apple TV, Sony BDP-S790, Mac Mini, BeoLab 11 , BeoPlay A8, pair of BeoPlay S3, Beo5, BeoRemote One . B&O product history since 1991: Ridiculously long to list in a signature.
I made the same settings change as soon as I got my BV11, couldn't stand the motion blur. Don't understand why B&O has this setting enabled as default. I do not think I've met or talked to anyone which thinks it looks better. Anyway, it's an easy fix.
I have the same problem!! I turn Judder setting to off but when I turn it off and then on again to watch it sets itself back to on!!!
I make sure that I store it before exiting the menu. Any ideas?
