HI
Does this model Apple TV fit into the rear compartment without adjustment? I remember reading a solution recently here, but can no longer find it I think it involved removing something from the compartment
can anyone help?
HI
can anyone help?
/forum/general-discussion-and-questions/my-dealer-showed-me-how-to-mount-an-atv44k-inside-a-bv11#post-2123075
Brilliant! Thanks a lot
By the way, can the part be removed without tools, just pulls off?
By the way, does removing the part require tools, or does it just pull out?
Just use a simple plier and bend the piece and it will come off.By the way, does removing the part require tools, or does it just pull out?
Finally, where do I put the B&O infrared sensor on ATV4?
