BeoVision 10 with BeoLab 8000 on wall bracket
Do U think it looks cool?
cool ? no. bv10 doesnt go well with the 8000labs. to long, to big ,not flat-----------
In that setup, they look fine.
I tend to prefer the BL6000 on wall brackets:
I do like the wall brackets on the 8000 - very elegant.
I like it....A LOT!
Loving it!!
I think the similar contrasts between the colors on the BV are similar to the BL, probably what makes it look good. I personally prefer 8000s on the floor.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
... and about 50cm away from the wall! 😎
That combo looks mighty fine to me. However, if I were to design the BL8000 wall brackets, I wouldn't make them quite so "tight" against the speaker, the conical base of the speaker makes this a difficult design task. These brackets make the wall mounting look a bit like an afterthought, which it of course is 🙂
The BL6000's on the other hand look superb on the wall!
Agreed! Does look nice with Beolab 8000's standing on the floor!
