Beovision 10 with 6000 speakers won’t play beosound 9000
hi
in the same room I have a beosound 9000, Beovision 10-40 with 6000 speakers attached wired via Beolink cable.
both now switch on off with beo4 remote and tv works and turns on speakers.  But I can’t make beosound turn them on.   Cd spins up but speaker light remain at red.
Tried loads of combinations but I’m not sure which to change that would cause this
Look for Masterlink Handbook to get very detailed information
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
BV10 i V.Opt 2 - BS9000 i A.Option 0....forudsat at der ikke er højtalere på 9000’eren.
Oh, sorry - the added sentence means: assumed that there are no speakers connected to the 9000.
Correct
BS9000, A-OPT 0
TV - V-OPT 2
Turn them both off at the mains, leave them for a few minutes - then power up the TV first, then the 9000.
You are using a Masterlink cable, right? Do you know for sure it works?
Ralf
Ill give it a try as I’ve never turned them off just standby
Cable worked with last tv so I’ve ruled it out for now
question -  what sound settings do you use for video and audio? I can’t seem to get tv speaker and 6000 to both work together
Default is: speaker 3 when sound from tv itself/video  -  two for what is coming from the BS 9000/audio ( = the external 6000’s alone).
Have a look in the settings/tv, if that should have been changed.
Have you tried manually (via the remote) to choose these - e,g. choose speaker 2, when the 9000 is playing.
