Beovision 10 speaker upgrade -> Beolab 4, Beolab 4000 or Beolab 14 4.1?
Aabo wrote:
Hi, I just went for a 4xBL4000 with the right Sn numbers (thanks!). This setup is perfect, they are so flexible if you want to move them a bit a round..
Thanks again
Kristoffer
Awesome. Enjoy them!
How about a picture?
Picture is coming! :) need to get them up, I have one more question. I've heard you can connect them in 'series' which would save some cables to your beovision.
I understand that you can do that from speaker to speaker, but how does the BV10 know which speaker it is (Front back L/R?) I have 4 DIN's in my beolab10..
Does this make sense?
Kristoffer
Yes, the TV will know - as soon as you set it up in the Speaker set-up.
I have done the same with Beosystem 3.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Kristoffer
You can not connect more than two speakers in series! Powerlink carries only left/right speaker!
Ralf
Well, you have to put the powerlink connector into the corresponding sockets.
There are two sockets for Front and two sockets for Rear.
You can pull one powerlink lead to e.g first front speaker and then continue to the second front. On the speakers you need to set a switch to either "right" or "left".
Not true for Beosystem 3. Used to be like this with older TVs. Changed to 2-6 powerlink sockets (plus sub and center). So you can chose any socket and start to the first speaker, from there to the second...
Ralf
Looked it up on the web. As Hiort wrote, just start with any front socket to attach the first and go from there for the second front speaker.
