Beovision 10 speaker upgrade -> Beolab 4, Beolab 4000 or Beolab 14 4.1?
I want to upgrade my BV10 to a more decent stereo setup (potentially surround) but I'm not sure what compact speaker to choose.
Sound sources will mainly be: spotify through chromecast, SACD through my NAS, and vinyls through my Rega p9
My choices are these:
BL 4000: A true classic compact speaker
BL 4: Are these good without sub? - or best for a rear speaker?
BL 14 - Im not sure about the design, sorry I think they look a bit cheap
Happy to get your input, most important for me is the sound, I would love to avoid a subwoofer
Kristoffer
Beolab 4000, s/n >1433xxxx to avoid issues with foam inside.
Great value for money and lots of option for wall mounting/table/stands.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Aabo,
I have a bv 7 40 with 4 beolab 4's and a linn sub...(5.1) no issues great speakers and compact🙂
What they are like without a sub unsure.......
Thanks! - does the SN refer to MK2?
Kristoffer
No, just the foam.
Beolab 4000 any day ... top spekar for the money.
Guys, thanks for the replies. Spot on..! gonna go with two BL4000. Perhaps 2 more if I want the surround...
thanks again
K
It will be great setup. Especially if you get 4 !
I use my BL4 as rear speaker. The bass is quite weak so I would not use them for front main speaker unless with a subwoofer. They look really good, specially in blue.
BL4000 has lot more bass and can be used without a subwoofer depending on taste. I use them as front speakers without a subwoofer. Very good value for money ! Good sound and they are a true B&O classic.
I have not had a chance to listen to the BL14 but if you don’t like the look of them I would go for four BL4000 instead.
Hi, I just went for a 4xBL4000 with the right Sn numbers (thanks!). This setup is perfect, they are so flexible if you want to move them a bit a round..
Thanks again
Kristoffer
