Beovision 10-46 if audio selected after video the picture stayes on ??
Hi there
I have a beovision 10-46 in my living room on option 6 and a bs 9000 option 0 and a beovision 10-32 option 2 in the dinning room.
connection works fine but if i select a audio feed after warching tv the radio comes on but the tv is still showen. To switch of the picture i have first to switch off the tv an then switch it in radio on again.
any sugestions ?
regards
Hi georgey007,
if you press RADIO on Beo4 in your living room (BV 10-46) you should hear radio of your BS 9000 and the picture should switch off automaticly.
Greetings
Räuber
Why the option 6 in the livingroom tv together wth the 9000?
Why not option 2? - and option 6 for the 10-32 (I suppose they are close together and might  both be reached with the Beo4 otherweise)?
Hi, are you using Beo4 or Beo5/6?
That's correct, dear Millemissen. But if I understood it right, BS 9000 and BV 10-32 are located together in ONE room (dinning room). In this case the option settings are correct.
Greetings
Räuber
Did you tried it with the AV-command (like AV-RADIO) on your BV10-46? Only audiosignals will be transported and the tv (= sreen) stays off. Just a suggestion?
This sounds like the reverse of my BV11 problem.
Sometimes  when I switch from radio to TV the radio still picture (even if previously picture muted) comes on with the TV channel sound. I have to turn the TV off and wait a couple of minutes and then start again. In my case I think it's some sort of software issue combined with a locking-up of the internal tuner module.
My problem only happens when the audio is coming first from the internal TV 'Freeview' tuner.... my Beocenter etc Is all now in a separate room and not connected to the BV11 which will not work with Masterlink.
Graham
"That's correct, dear Millemissen. But if I understood it right, BS 9000 and BV 10-32 are located together in ONE room (dinning room). In this case the option settings are correct."
Dear Raueber,
well, I did understand that the audio system 'is located' with the BV10-46 - most people would do so! - and that the 10-32 is a link-tv
Untill it is clear what Georgy wants, we don't come any further.
Greetings Millemissen
Correct. Gregory has to make us clear what is located in the livingroom and in the diningroom. And is the equipment connected via ML?
That would make it a lot easier to tell Gregory how he can set the options and he has to make us clear what he wants. I think it is better to wait for a reaction, before we know how he has setup his audio and video. Perhaps forget my solution till sofar.
Hi
wow i must say a lot response :)
ok it seams that i have to lay out my whole setup.
In the dinnig room ( kitchen )
one beosound 9000 in option 0 as audio master
one beovision 10-32 as videomaster option 2 with beolab 4000 conectedn
as an extra listen zone beolink aktiv with pair of beolab 8000 in option 4
one beo4 as remote for this room
in the living room one beovision 10-46 with 1 beolab 1 2 beolab 6000 and 2 beolab4 in option 6
Bedroom one beovision 10-40 with beolab 1 in option 6
bathroom one beolink passiv in option 6
all with beo4 and masterlinkgateway
the audio master is playing well everywhere even in the livingroom
only thing is that the picture on the tv stays on when i switch to audio and istnt switching the display to black and after a while off
the 2 other beovision 10 are behaving as they should
regards
