Beovision 10-46 defekt
Jetzt schon? Eigentlich zu schnell :(
Mine has same issue.. Just received answer from b&o ther is no more panels to order.. So possible I will throw mine away if I do not find any other solution...
Hello. do they say something about what's wrong? tcon or panel?
Panel they said to me... Login to view image
Then it’s posible I can help you.
I have a panel that might help.
But which country do you live in?
Sweden...
Ok, jeg bor i Norge :). Si ifra om du trenger deler.
Ok. Jag trodde utefter det du startade tråden om att du hade en tv som var trasig?
