Beovision 10-32 on its way !?
Roger wrote:
The BV10-32 will take the place of the BeoVision/Center 6 series for link rooms.
Sounds confirmed... WOOHOO! Great move! I was just pricing panels for the kid's rooms... now I will wait! 😁
BeoGreg wrote:
the latest software update (build 126) wich do a great job for the "clouding issue"
Build 126 for BV8-40 BV10-40/46 (C2 chassis)
has been withdrawn (removed from the service tool)
andhas been replaced by Build 127
Build 127 fixes the DVB-HD blocking problem
(if Radio and then standby was selected)
Some new STB's on the PUC list, naming of sources à la BV7 and
yes, hidden in the "Forbidden City" , ...
>>The BV10-32 will take the place of the BeoVision/Center 6 series for link rooms.<<
That is a bit of a pity. The design of the BV6 is very different then from the BV10. Try placing the BV10 on a shelf.
I don't fully understand why it is so tricky to run the TVs on the same platform and retain their frames.
I always loved the Bv6 and am still sad it never made it to the US.
The picture is darker from standard set up, so the black looks more black and more uniform.
It's not annoying anymore, and I know what I'm talking about, my first BV10 as been changed for severe "clouding issue".
But instead of having a too bright picture now there's a slightly dark picture. But you can play with contrast in the menu and it's perfect.
Cheers,
Gregory
Can I update my BV10 myself, or does this has to be done by service tool?
When was Build 127 released?
I do not have DVB-HD installed, but I want the possibility to name sources.
/C
- You'll need the service tool (and your dealer/service)
- Beginning of the month
My hope is that if B&O are making a BV10-32 then they have a right size panel (32") to update the BV-7-32 with a modern panel (and hopefully an updated Beosystem 3 "lite").
One can dream !!
Quite a large gap from 32 to 40. 37 somewhere in the LCD range would be a useful addition.
No one has any more news on a BV10-32 then ?
BeoGreg wrote:
Guys,
I can confirm that my B & O tech said the clock as been replaced by a small B & O logo on the right.
I can't confirm it from my experience because we are still working on how to get my DVB-HD module back to life.
Since a PUC update I lost my DVB-HD, it's n/a in the service menu for no reason.
The last information from B & O (total reset - stick USB in for 4 minutes - unplug without standby - restart) didn't work.
Like you, I whant to know !
Cheers,
Gregory
Hello,
now I have the same problem: Two days after updating my BV10-40 with software build 127 my HD module is dead (n/a in service menue). A reset to factory settings does not help, also a special instruction-sheet from B&O support (total reset - stick USB in for 4 minutes - unplug without standby - restart) can´t wake up the HD module. My dealer will now replace the HD module, but I fear build 127 had killed the module!
I am very disappointed!
/Räuber
