Beovision 10 11 14
Hi
Did the BV10 have the connection panel at the top or is that only the 11 and 14 ?
My BV10-40 has all connections at the bottom
Ferdinand
Thanks.
The hotel I stay has 2 BV in the room
It has a BV10-40 in the bedroom with no connection panel
The one in the lounge room has a connection panel but it has a fixed wall bracket so I can’t pull it forward to check lol.
I would bet that it does: The power cord goes into the same "hollow cable rail" as the other connections, so if you can find its entry point, you know where the plastic cover panel to that cable rail is.  Not sure how a hotel would go about making the cover non-removable, but screws come to mind.  The regular BV10 should have 3 magnets on the top edge of the cover and 2 or 3 rubber-on-plastic inserts (like speaker grilles often do) about a cm from the bottom of the cover and a few cm in from the ends.  Once you examine and access the TV that can be moved, you'll probably be able to pop the panel off the fixed-mount as well, because it takes very little horizontal movement to release the inserts, and probably the wall mount is deeper than that.  Hmm... should we look up the replacement part price so you can pay the hotel for cracked plastic bits?
Lol.
I’m not referring to the connection panel below the screen.
I’m talking about the quick access one at the top
That is sometimes here
This is the bedroom one.
I was just wondering about the one in the other room that is fixed so I can’t see which model it is.
I very much like the picture quality.
Aussie Michael wrote:
Lol.
Only BV11 mk1 and mk2 had quick connections pannel.
Thanks everyone. Worked it out.
The label was under the speaker cover.
It’s a BV11-40
The 11 has the better sound I think than the 10.
It’s a BV11-40
It sure has
It’s a BV11-40
Yes it does.
