I need your help ;-) Just want to know which serial of BeoVision 7-40 means which MK ?
Further I want to know the differences between the MKs - the original website isn´t very helpfull.
Thanks / Kind Regards
Thomas
Thomas
Thanks for the input - but the seller resides on ebay and just posted the sn. He will be able to check for the type upcoming weekend :(
Btw: Is there a chance to upgrade the DVD Player to an Blue Ray-Player ?
Further Update: it will be type 9331 incl. Sat Receiver - will this be HD ?
Salut,
J'ai besoin de votre aide , le miens est un 9364 que pensey vous du type ? merci
super merci , mais je suis en France quel demo TNT me conseillez vous ?
SUPER merci , quel démodulateur pour la France me conseillez vous ?
