My Beotime (the original clock) has started to loose time. Guess the clock parts have just worn out.
Where would I get another that will take the same hands ?
Any ideas ?
Any ideas ?
Do you know the make of the original movement? It should be on the back. If you know that, you should be able to find out the spindle sizes and find a modern day equivalent (as I believe the original movements are no longer available). There are dozens of clock parts sellers on the net. Alternatively, you could try measuring the spindles and find the equivalent. I know you'll want to keep the original hands and will want to swap them over.
Thanks for link Dave !
Interesting stuff he works on (older watches) but I think he may cringe at the quartz movement on the Beotime.
Dave.
The movement on the beotime I have is made by Kienzle quartz Germany.
I will open it up and have a look before replacing it.
Do you know the make of the original movement?The movement on the beotime I have is made by Kienzle quartz Germany.
OK, you could then try to ask a Kienzle Tech guy a question about an equivalent replacement:
http://www.lulusoso.com/products/Replacement-Kienzle-Quartz-Clock-Movement.html
Ths awkward part is the second hand I think from what I've seen so far.
Or, if the calibre number is visible, you could try searching or asking here:
[quote user="Dave Farr"]
Quartz is no problem what I can see.
I have used his service once, with a Rado. No problems more then find a slot for repair!
http://watchguy.co.uk/?s=Quartz&submit=Search
