Beotime control over beoplay M5
I would like to switch on my beo play m5 using My Beo time alarm is this possible? If so can you instruct me please?
There's no easy way to do this. If you are good with software people have managed to make B&O IR decoders on Arduino and other platforms. It should be possible to write code that receives the IR codes and converts them to BlueTooth commands on an Arduino or RaspberryPi.
A lovely idea. IR control (Beotime, Beo 4...) for the newer Bang & Olufsen Bluetooth products.
You would need an infrared to bluetooth converter.
Those things were / are available e.g. from Logitech and RE-BL (there's a PUC from B&O for the RE-BL, too) to control the Sony Playstation 3.
1.) RE-BL: link (only PS3 as far as I know)
2.) ir to Bluetooth for Playstation 4: link
But the question is if it is pairable to a B&O Bluetooth speaker and how it reacts.
Isn't there an alarm function in the M5? I know there is in the M3.
This is not the answer to your question, but it may solve your problem..
Yes there is.
