Recently acquired one but having problems setting it up. Have spent about £30 on all sorts of additional connectors, none of which make any difference.
I have 2 telephone points both in the lounge. A primary socket and a secondary box/point attached about 5 metres away. My Sky wireless broadband router, BeoCom 5 and PSTN base are all plugged in (and working correctly) to the primary socket. Want to get the 1100 going from the secondary where currently nothing is attached.
Started out with the setup as illustrated in the manual but to no avail. Have tried replacement cables, swapping cables over (i.e. putting Power into Line or vice versa) and different socket converters i.e. RJ11 to BT and/or back again. All sorts of combinations. Did at one point manage to get it going, at least the display came on and I could program the time, date and record my messages. However, in this one and only instance, 'Line Busy' showed up on all the telphones so I could never make or receive any calls. There was also a continous low level humming noise instead of the proper dial tone and the internet lost its connection as you would might also expect.
Any help would be greatly appreciated.
Thanks,
Simon.
