beosystem av 9000 help
hello guys, I have a problem with my B&O, my tv was working fine but we were moving the tv from one house to another and strangely the B&O stand cable, which I assume is the most important one is broken. here is a picture:
but the problem is that I dont think the cable can be changed because it comes out of the stand itself like shown here:
can anyone help? I cant show any content on the tv screen because the stand contains all the inputs. thanks in advance.
There should be enough cable lenght for resoldering the plug back on. When I look at mine it looks like it's possiple.
thank you for replying, but please can you further explain how to do so? I dont want to make things worse.
Don't remove the cable, but rather the plug. Disassemble and either color match the broken leads or use the diagram below.
Either solder the leads back to the plug, or have a friend help if you are uncomfortable with soldering.
P.S. Welcome to BeoWorld! 😁
I would get a pro to do it. First and foremost.
So that would mean the local B&O shop.
You would need to locate the right wiring for the plug and then solder it back on.
Any B&O shop could provide that at least.
If the cable is not long enough you would need B&O to open the bottom part anyway to change the whole cable.
Its not a big repair.
You can try Beotech to find the wiring diagram.
[quote user="Friedmett"]
thanks for all the help guys, I appreciate it. :) I'll ask the B&O shop how they can help.
