Hi All,
I'm hoping this is a simple question - but my research has not found a satisfactory answer so I thought I would ask it here.
I've got a Beosystem 7000 and I'm wanting to add a couple of extra link rooms. However the layout of the house does not lend itself to easily running cables without damaging the decor. I have a spare BeoLink active - and a Beolink converter type 1611, however I'm now thinking that it might just be easier to use BeoLink Wireless 1. It would also mean I could move the equipment to another link room if I wanted to at a later stage
I've looked at the documentation and Beosystem 7000 is not listed as compatible with BeoLink wireless. However - would it work if I connected the transmitter up through the Beolink Converter?
Thank you for your help
Mark
