Beosystem 5500 Questions
Evening Guy's......
I've recently aquired a Beosystem 5500 minus the CD player and have some questions.
Does anyone on this forum know of, or where I could get a matching used Beo 5500 CD player - I'm not too concerned about the appearance although a working unit is a must.
The record deck is near mint but I need a cartridge, so again any members have an MMC available
And lastly, the Tape deck plays great although the eject fails - the motor can be heard but the unit won't eject - I have to pull the tape deck out - is this an easy fix.
I'd like to avoid Ebay if possible as bidding wars "do my head in".
Linked to my Penta's it really does sound pretty good, but I'd like to fix the issues referenced above.
As always any help would be greatly appreciated
Steve
Well I was going to suggest Ebay for a Beogram CD 5500, but you say you don't want to go down that route. As for a cartridge, I would suggest getting a new one from
Hi Steve
I've sold two recently on ebay
link
 link
I have got another one for sale that has been serviced which I could let you have for £165.
Whereabouts are you - I might be able to deliver it.
Cheers
Nigel
Hi there........
Thanks for contacting me - I'm very new to B&O and am probably holding out for a cheaper unit.
However I'll come back to you if all else fails.
Cheers
Steve
You won't get one much cheaper than that!
The cd player is the bit that's worth all the money. The beomaster and the tape........well you can hardly give them away!!
Hi Steve.
I might have an MMC unit you can use. MMC 3 if memory serves me.
You can PM me if you are interested.
Razz
If anyone else wants it before it goes on ebay please shout!
Cheers
Nigel
Bargain! Which one is it? Early or late? I wouldn't say no to an early one!
You can actually see the difference in the 2 I've recently sold - the later ones had an additional ring on the CD tray to take smaller CDs - there may be other differences that I don't know of.
Peter - I do have an earlier one which has been fettled By Tim J. (dry solder joints). I went to have a look for it's serial number and was a bit shocked to find the serial number label has been removed😉 I can assure you I paid good money for it, but as to it's previous history, I wouldn't like to say😁 Let me know if you're interested - I could deliver it up to you at no cost - it would be a pleasure to meet up with you. I also have a later one, serial number 6264164. I also have a CD50 serial number 4466753.
Cheers
Nigel
